Gripdana wrote:Last night I had a heck of a time drilling my lower firewall to the fuselage. I pilot drilled all the other holes in the firewall stainless with relative ease. But for some reason I am having problems now. All the bits do is scratch the SS. I have tried cobalt and titanium bits with lubricant and slow speed as well as fast speeds. Dors anyone have any suggestions?
sonex892 wrote:Sounds like you need to push harder. More feed less speed is the trick with stainless and always use cutting fluid. If you don't have swarf you're doing something wrong. Never use a blunt drill bit, throw blunt ones away. All a blunt bit will do is generate heat and make the stainless even harder!
With the correct technique should be possible to drill all holes in the firewall with one bit.
