rivet gun nose size
rivet gun nose size
Postby iancshippee » Tue Nov 02, 2021 2:49 pm
Hi all, when my friend gave me his sonex project he included a number of different tools, including a textron rivet gun. it appears that for some spots, the nose of the gun is a bit too wide for the space (riveting wing ribs, for example.) does anyone know if there's a narrow nose attachment for this gun? searching the web has left me empty-handed so far. I'll reply with what exact model gun it is later on, I'm not home at the moment and can't remember offhand!
Sonex A project #0823
N1127S reserved
Foster, RI
iancshippee
Re: rivet gun nose size
Postby Bryan Cotton » Tue Nov 02, 2021 4:48 pm
I'm not familiar with that gun, but I've ground down a few nose pieces before. I find that I can swap nose pieces between my pneumatic guns and some of my hand guns.
Postby WesRagle » Tue Nov 02, 2021 4:56 pm
I've ground down the nose on my hand puller before but never have on my pneumatic.
I'm not sure exactly what problem you are having, but this tool can often be helpful in tight spots.
https://www.cleavelandtool.com/products/close-quarter-rivet-pulling-wedge
Good Luck,
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Postby kmacht » Tue Nov 02, 2021 5:16 pm
For tight locations buy the $30 harbor freight pneumatic river gun and use a belt sander to shave down the nose. That is what I did on my project and it worked great. The rivet gun is cheap enough that even if you only use it with a ground down nose for tight spaces it’s worth it.
Postby Bryan Cotton » Wed Nov 03, 2021 8:09 am
kmacht wrote:For tight locations buy the $30 harbor freight pneumatic river gun and use a belt sander to shave down the nose. That is what I did on my project and it worked great. The rivet gun is cheap enough that even if you only use it with a ground down nose for tight spaces it’s worth it.
The really cheap HF hand rivet gun tips interchange with the pneumatic tips.
Postby Spaceman » Wed Nov 03, 2021 3:43 pm
Search on ebay for a "PRG 410" rivet tool. It's way narrower than anything else I've found. I think I found one on ebay for less than $20 and it's been super handy many times on my build!
Chris Paegelow
http://paegelow.blogspot.com/
Spaceman
Postby Bryan Cotton » Wed Nov 03, 2021 5:40 pm
Spaceman wrote:Search on ebay for a "PRG 410" rivet tool. It's way narrower than anything else I've found. I think I found one on ebay for less than $20 and it's been super handy many times on my build!
viewtopic.php?f=34&t=2345
Postby iancshippee » Thu Mar 24, 2022 11:31 am
Thanks for the input, everyone! the original builder sent me a care package of some more specialized tools he had packed away, and I'll be picking up a few more of my own as well. project went on hold for a short time; my wife "commisioned" me to rebuild a tractor for someone, and that project is nearly done. I'll be happy to have my work space freed up again!
N1127S reserved
Foster, RI
iancshippee
Postby lakespookie » Tue Nov 01, 2022 6:41 pm
PRG-412 is also an acceptable narrow headed riveter you really only need it for the first 3 ribs and for the rest of the ribs the wedge is all you need
Jill's Build Log
PPL-ASEL
Tail = Complete
Wings = Complete
Waiex-B 0054
Panel G3X
lakespookie
Return to Tools
