Fuel flow test
Posted: Sun Dec 01, 2019 11:30 pm
I'm about to perform a Fuel flow test on my Onex which uses a 85HP Hummel engine and was hoping someone can confirm my figures
The formula for a Gravity feed system( obtained from EAA webinar on fuel flow test) is HP X BSFC X 1.5 X .36 = ounces per minute
The fuel consumption for the Hummel at full power is approx. 5 gal/hr.or 30 lbs/hr
I obtained the Brake specific fuel consumption from http://www.wallaceracing.com/bsfc-calc.php which was .35
85 X .35 X 1.5 X .36 =16 ounces per minute
So I require a minimum fuel flow of 16 ounces per minute at full throttle in a maximum takeoff climb angle + 5 degrees
Anyone see any problems with the above?
Thanks.
Mike
Thanks.
Mike
