Sonex Fuel Tank & Oops Fittings
Have you spun the fittings in your Sonex (roto-molded) fuel tank?
Yes, and I repaired it with an Oops fitting
10
33%
Yes, and I repaired/sealed it with a different method
7
23%
No, I am still using the original fittings
13
43%
Total votes : 30
Re: Sonex Fuel Tank & Oops Fittings
Postby kevinh » Wed May 20, 2015 12:09 pm
Bryan Cotton wrote:I think the idea to make tanks without the molded fittings is a great one. Would make the job easy.
Yep. I recently ordered my kit and it will be a bit of a hassle for me to to the same work you just did. It seems given the high rate of leaks with the molded in fittings that Sonex hasn't opted to do just what you describe. Over the next couple of years of building I'll have to decide if I'm going to go with the built in fittings and hope, or bite the bullet and do the mod preventatively.
kevinh
Postby Bryan Cotton » Sat May 23, 2015 12:16 pm
So on my initial leak check the only fitting that did not leak was the small fuel sender fitting. Ironically I did the worst job on that hole. Just goes to show that it is all about the O ring and its sealing surface. I am going to take out those two fittings because I don't want water trapped in there. I think on round 2 I will use air, because the inside of the fittings will stay dry. I can look for soap bubbles and torque the oops fittings until they are gone.
Postby Waiex 49 » Sat May 23, 2015 12:39 pm
Hi Bryan,
Nice job on the "oops" fittings.
You may want to consider using some locktite on the fittings.
I used locktite on mine, didn't want them to come loose while I was flying around!
Seems it is much easier to do these fittings while on the initial build.
Having to remove and replace the fuel tank to make these repairs is no fun.
Waiex 49
Postby Bryan Cotton » Sun May 24, 2015 12:18 am
I thought I had a good wrench collection but my wrenches were either too thick or too small for the oops fitting. Also, I am not sure if they are SAE, metric, or whitworth. So, I made an oops fitting wrench out of 1/4" plate.
Re: Sonex Fuel Tank & Ooings
Postby WaiexN143NM » Sun May 24, 2015 2:43 am
Bryan,
And to everyone, the oops fittings I ordered from sonex have grooves machined on the inside the tank flange side. A green o ring on the 3/8 larger fitting and black o rings on the 1/8 fittings. The green o ring fits nicely in the groove, but the black o rings on the smaller fittings seem to large to fit and seal in the machined groove. Any one else notice this? They are too large to fit in the groove and then seal properly. Will measure and get some Viton o rings to fit.
Michael RADTKE
Postby DCASonex » Sun May 24, 2015 9:46 am
WaiexN143NM wrote:Bryan,
Michael RADTKE
Yes, had similar problem two years ago. At that time, Sonex just bought these off the shelf from another supplier, and had no knowledge of the O-ring size or their material. I replaced the O-rings on smaller fittings.
Postby WaiexN143NM » Sun May 24, 2015 3:52 pm
Hi David,
Yep now i remember reading your post a couple years ago, thanks for the reminder. Bryan this could be part of your leak problem. Take one of the small fitting out and apart and size the o ring with the machined grove, u may find the o ring too big.
Cheers to everyone on this nations holiday memorial veterans weekend !
Michael Radtke
Postby Klimek » Sun May 24, 2015 9:16 pm
Bryan,
Not being nosy, but would it be better to check the fittings with a solvent
Or something like kerosene or the like. When I would complete a VW valve
I was trained to check the seating with kerosene. It will go where water
Won't. I think it has something to do with viscosity, surface tension or
The like. Some of you scientists / engineers would know.
Frank
Klimek
Postby Bryan Cotton » Sun May 24, 2015 9:26 pm
Frank,
I agree. A check with water is good because it is just water, and if the water leaks it is definitely no good. I am going to use compressed air and soapy water next.
Postby SonexEZ » Wed Dec 09, 2015 3:18 pm
WaiexN143NM wrote:Hi David,
Michael Radtke
Hi I have a leak but its on the hex head right side of the fuel tank its not the oooppp fitting i have tried several things still seeps ,
SonexEZ
