BRS wrote:There are four locations on my tank. One large and three small. Two of them are for a fuel sight tube which I don't use (didn't change them) the third small one is for the fuel level probe (not leaking didn't change). I believe the large engine feed fitting leaks because of so much attached to it trying to wiggle it. Not only is there a valve but often times a fuel cube. These put side loads on the fitting.
Follow up and end of the saga (hopefully). Finally my tank (large fitting) is replaced and the loaned tools are headed back to the owner. I used a small amount of fuel-lube (EZ Turn) where the threads and o-ring meet. The idea was that the plastic ends up with scratches the size of the last grit used and I wanted to have a bit of this to help fill them. Tank was leak free the first try. Here is my before/after pic
Bryan Cotton wrote:I did the two small ones and the big one in the sump. I didn't bother with the high one.
tps8903 wrote:Did you do it in the plane? Or remove the tank?
DCASonex wrote:FWIW: It was one of the small ones on the bottom that first started showing leak on mine but then the larger one also started leaking. Drilling out and the large one first leaves and access hole that, makes it easier to work on the small ones.
