Area 51% wrote:Why couldn't you get the spark plug senders to work? I know there's a little step down to the plug seat on my heads that wanted to distort the sender, so I got some aluminum oil pan gasket washers to put between the plugs and head to eliminate that miss-match.
GraemeSmith wrote:Area 51% wrote:Why couldn't you get the spark plug senders to work? I know there's a little step down to the plug seat on my heads that wanted to distort the sender, so I got some aluminum oil pan gasket washers to put between the plugs and head to eliminate that miss-match.
But doesn't that mean your plug doesn't reach as deeply into the head? That's not good for flame propagation and efficiency.
sonex1566 wrote:The way that I've got it at the moment has to measure a bit cooler, it's just how much cooler is what I'd like to know.
