Bryan Cotton wrote:Thanks John. Sounds like I should get one of each if I understand.
For the tank straps, should I pre-bend them to the tank?
fastj22 wrote:Bryan Cotton wrote:I am going to pre-emptively add the oops fittings. Do you replace all 4 small ones and the large one?
Replace the ones that will be immersed and you may want to remove later. If you are just going to plug them and not use the sight gauge, that one can stay stock. The big one and the fuel probe one are the ones that fail.
Waiex 49 wrote:
Having been through all of this, if I had to replace one of the smaller fittings in the sump I would carefully drill it out and screw into the tank a 3/8" NPT reducer fitting (bushing). Much easier than the oops fittings.
