radfordc wrote: I did have some issues with the enamel. When I shot the black over the white I got a lot of "curdling". I may not have let the white cure long enough.
I had the same issues when I started painting with Rustoleum. Per the instructions on the can, you either have to paint additional coats withing a specified period of time (a few hours) or you should wait at least 48 hours [I think that's what the can says] before recoating OR before adding a clear coat. I was painting the color, then putting on the top coat a day later. Results: extreme orange peeling! Had to use paint stripper and start over. I got ahold of Rustoleum and they said the clear coat (especially) has chemicals that will react with the paint and orange peel any paint that is not COMPLETELY cured. So on my next paint jobs I primed, waited a couple of days, color coated multiple coats all in one night, and then I waited a WEEK before I clear coated. If I needed to do any sanding after the color coats, I waited a WEEK before recoating, and then waited another WEEK before clear coating. It's worked so far.
I know of at least one builder (I know there are more) that didn't clear coat at all. They just used car polish after painting, and that shines it up and adds some protection. They were happy with the results.
