Vinyl Wrap
Vinyl Wrap
Postby pfhoeycfi » Sun May 10, 2020 8:04 pm
I would like to wrap my control surface with a simple checkered pattern. Can anyone recommend a vendor where I can order thae product and pattern?
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
pfhoeycfi
Re: Vinyl Wrap
Postby sonex1374 » Sun May 10, 2020 9:24 pm
Peter,
John Gillis talked about vinyl wrapping including suppliers on episode 36 of the podcast. That might help get you going in the right direction.
http://www.sonexflight.com/36
Jeff
Jeff Shultz
Sonex TD, 3300, AeroInjector
Kansas City, MO
http://www.sonex604.com
sonex1374
Re: Vinyl Wrap
Postby onex28 » Sun May 10, 2020 11:16 pm
I took my rudder to a local sign shop in MN and they did an excellent wrap of a checkerboard pattern.
Onex 28
onex28
Re: Vinyl Wrap
Postby pfhoeycfi » Mon May 11, 2020 7:36 am
onex28 wrote:I took my rudder to a local sign shop in MN and they did an excellent wrap of a checkerboard pattern.
Onex 28
Thats prob the smart way to go.
Peter Hoey
pfhoeycfi
Re: Vinyl Wrap
Postby pfhoeycfi » Mon May 11, 2020 8:20 am
sonex1374 wrote:Peter,
Jeff
...had forgotten about that issue, listened again this morning,
Peter Hoey
pfhoeycfi
Re: Vinyl Wrap
Postby XenosN42 » Mon May 11, 2020 8:43 am
pfhoeycfi wrote:I would like to wrap my control surface with a simple checkered pattern. Can anyone recommend a vendor where I can order the product and pattern?
Hi Peter,
My OneX was wrapped by a company located in Slatington, PA which I think is very near you. https://www.idwraps.com/
To do my checkerboard they placed each black square by hand. They are real artists! They can also print a design.
-- Michael
OneX N169XE
XenosN42
Re: Vinyl Wrap
Postby Area 51% » Mon May 11, 2020 11:26 am
I prepped my instrument panel for painting (roughed it up) before I saw a couple of panels with "the carbon fiber look". Love it!
I'm guessing it's a vinyl overlay. Can anyone tell me if the vinyl products will adhere to anything other than a smooth/shiny surface? I'd really like to have that look, but don't want to polish the panel first.
Re: Vinyl Wrap
Postby racaldwell » Mon May 11, 2020 5:12 pm
Or make a carbon fiber overlay. I don't have a picture but I could get one Thursday if you are interested. Easy to make and your bare panel with the holes cut out is the template. I finished mine in March and used water slide decals for labels. Works great.
I made one for my RV-6 and it now is 20 yrs old and still holding up just fine. Some of the decals for ON/OFF on the frequently used switches have rubbed away but after the initial inspection, who cares? Toggle up is on, nobody will forget that.
Rick Caldwell
Xenos 0057
racaldwell
Re: Vinyl Wrap
Postby jrs » Mon May 11, 2020 6:26 pm
I've ordered some samples from fellers.com. A 12" x 12" is only $2 or $3. Also ordered VViViD XPO Black Carbon Fiber from Amazon and a 12" x 60" was $10. Small investment to see how it works. It seems to stick well to anything that is clean. No magic about polished surfaces.
jrs
Re: Vinyl Wrap
Postby pfhoeycfi » Tue May 12, 2020 7:56 am
That looks great. I'm curious, are the squares 2 x 2?
peter
Peter Hoey
pfhoeycfi
Return to Finish methods
