Painting polished airplane
Postby Pickleman » Sat Oct 11, 2014 11:24 am
For those of you that polished then added trim paint, what steps did you take to clean and prep the area to paint? I was worried that some of the harsher washes and chemicals could/would creep under the tape!
Pickleman
Re: Painting polished airplane
Postby ScottM-Sonex1629 » Sat Oct 11, 2014 12:11 pm
Take a look at my other post on painting and polishing. I would recommend using PreKote. Tape off the area you don't want to paint. Use a high quality painters tape. Now spray apply the PreKote to the area you want to paint, and follow he directions (scrub with red scotch brite pad) reapply and scrub a second time, then rinse with water.
Once it is dry I would reapply the tape at the same line, apply the primer (recommend 2K epoxy) then paint, etc.
Scott Meyer
Sonex 1629 - Sold...9/2019
ScottM-Sonex1629
Return to Finish methods
