Hi Guys,
First, I would like to apologize for one of my previous posts.
WesRagle wrote:Hi Michael,
Ladies and Gentlemen ..., watch in amazement as I, Silvatron, by applying only a small amount of Nuvitoninum (found only on my home planet), transform this seemingly ordinary piece of aluminum into the near invisible Alumanimum. Some may proclaim this to be alchemy, but don't be fooled, ...
Wes
Most of you, and certainly any trained therapist, will notice immediately that one of my more dominant alter egos, "The Wizard of Odd", was trying to usurp the powers of Sivertron. If you've spent any time with a true Super Hero you'll know they never boast.
Ok, maybe I'm a little wacked, but I'm fresh off of a 30 hour polishing fit so perhaps you'll understand.
While it's fresh on my mind I'll make a few observations. First, I re-read the thread and picked out some of the statements that resonated with me.
1) No "one" technique is "the" technique. You will get other opinions on the above, and they will likely work as well. These ones have worked for me.
2) It seems to me that the best polishing is actually had when the polish is just starting to dry up and pick itself up... i.e. when you're polishing at the point where it's just starting to look clear as you move across the surface. If you stop and reapply before that point you're missing out.
3) Do yourself a favor and polish the bottom well before assembly. Trust me, you do not want to polish laying on the ground holding that polisher above you. Ask me how I know!! Ditto.
4) No one said this was a clean job.
5) It gets to a point of diminishing returns. Each pass still takes just as long, but the improvement starts to become VERY small. At some point you'll cry uncle, and that's the point to switch to Nuvite C.
Note: On #5, it is hard to know when enough is enough. The whole point of polishing is to play tricks on the eye. The game is to have the eyes automatically adjust focal length to see the reflection and not the surface. After hours of polishing I tend to lose objectivity. I found an objective way to judge. I used 1200 grit sand paper to scuff up a spot in the middle of the area being polished. Then I polish that spot the same as the rest of the area. Polish until the spot looked the same as the surrounding area. YMMV.
Here is what I reported after "Polishing Fit #1"
1) Stick my finger tip in the polish and dab dab dab ... the polish over the area to be polished.
2) Stand back (and above) with a mist bottle full of mineral spirits and give it about 1/2 a trigger of mist.
3) With the buffer on low speed swipe the entire polish area. This will spread the polish over the area.
4) Once the polish is spread roll in some speed on the buffer. Keep it moving. Back and forth, up and down, .... Usually up a little on the edge of the pad.
5) Keep going with this application until the polish is removed by the pad. As the polish starts to be removed I speed up the buffer and lay it flat.
6) Repeat as necessary to get desired results. It takes about 6 passes of F9 to get the grain down to an acceptable level.
Here are some comments after "Polishing Fit #2"
Note on #0: Add step 0. Clean entire area with laquer thinner to remove all printing, sharpie marks, bug poop, etc off of the surface.
Note on #1: It is hard to over emphasize that it is way too easy to get too much polish on the surface. The large can of F9 that I showed in the previous posts should be enough to polish two or three airplanes.
Note on #2: There is a perfect amount that will come with experience. Just enough and you can easily spread the polish over the area. Too much and you will sling "stuff" all over. Not enough and you will have just a splotch of polish where the finger prints of polish were. As I got tired (lazy) I used more mineral spirits and didn't even spin the pad while spreading the polish. It was messier but used less effort.
Note on #3: If there is no polish on part of the surface I don't think you're going to do much good. After spreading, the entire area should be covered/coated.
Note on #4: During fit #2 I didn't add speed to the polisher for the first few seconds of the application. I quickly moved the polisher side to side over the entire area with no pressure and the pad flat on the surface. Within a few seconds the entire area (1/4 of the surface of the outer wing panel) would reach the "magical point" that Ryan pointed out, "when the polish is just starting to dry up and pick itself up". The surface looks dull gray. Sometimes it looks a little like gun bluing <sp>. At that point I would roll in just a touch of speed and get up on the edge just a little (maybe 10 deg.), apply a little pressure, and start moving forward and backward going a little farther forward with each stroke.
Also, for the first 2 or 3 passes don't get up on the edge at all. Just leave the pad flat on the surface at low speed, no pressure, keep it moving, and let it pull. If the F9 is doing it's job the metal will heat up some. The metal might expand, pop and complain some. Don't worry about it. After three passes the metal will be getting bright. You can start adding shine/reflection at that point.
Note on #6: Probably a gross under estimate of the number of passes.
I don't do small areas. For the vertical stab the entire side is my polish area. For the outer wing panel 1/4 of the surface is my polish area.
I am now about 7 full days in. The only areas that haven't been hit are the wing stub skins, flaps and ailerons, and the leading edge of the tail surfaces. I will still have to do the C and S after the plane is assembled. That shouldn't be too hard. The F9 is definitely the "heavy lifting" part of the job.
I do have to say that polishing is a hard and nasty job. If you are doing this in your garage, cover the entire floor with plastic before starting. Find yourself a pair of shoes that are about ready for the trash and use those for the job. Never, and I mean never, wear those shoes into the house. Burn the shoes after polishing. After a polishing session remove your shoes, ask someone else to open the door for you, pull up your paints legs and tiptoe directly to the shower. Undress in the shower, turn your cloths wrong side out and hand them out for a trip directly to the washer. Apply lava soap (repeat as necessary).
Anyway, if you really really want a polished airplane and have problems getting started don't feel alone. I think most folks are stumped at first. If you are having problems, get yourself a mister bottle full of mineral spirits and experiment some. You will probably find a combination that works for you.
Best of Luck,
Wes
