Rattle can
Rattle can
Postby Bryan Cotton » Wed Nov 13, 2013 6:01 pm
Hey all,
I have seen a couple references to rattle can Krylon paint jobs, especially on minimally painted airplanes. Anybody have any thoughts on this? I will only be painting the fiberglass parts and it seems viable, though the cowl is sort of a big part.
Re: Rattle can
Postby radfordc » Wed Nov 13, 2013 10:56 pm
Here is an example of a rattlecan paint job with vinyl markings.
Joesie 4.jpg (315.94 KiB) Viewed 18571 times
Re: Rattle can
Postby Bryan Cotton » Wed Nov 13, 2013 11:01 pm
That looks pretty good. I also saw this one in the Sonex completions:
Re: Rattle can
Postby Bryan Cotton » Thu Nov 14, 2013 2:31 pm
A couple more questions for the rattle-canners:
1) krylon seems to be the popular choice. Why not some other brand?
2) how many cans?
3) prep - did you prime at all, or just bondo-scratch-squirt?
Re: Rattle can
Postby radfordc » Thu Nov 14, 2013 6:14 pm
Bryan Cotton wrote:A couple more questions for the rattle-canners:
2) how many cans?
I used Rustoleum.
The red is lacquer with gloss clear coat. http://www.rustoleum.com/en/product-cat ... quer-spray
The black/white is high performance enamel. http://www.rustoleum.com/product-catalo ... amel-spray
Lots of cans of the lacquer on the cowl and tips (maybe a dozen or so). I think only a couple cans of black and white. I did have some issues with the enamel. When I shot the black over the white I got a lot of "curdling". I may not have let the white cure long enough.
I used gray sandable primer for the fiberglass parts. http://www.rustoleum.com/product-catalo ... imer-spray
I used self etching primer from the auto store on the aluminum. Scuffed the aluminum with scotchbrite pads.
Re: Rattle can
Postby MichaelFarley56 » Thu Nov 14, 2013 8:22 pm
I'm right there with Charlie... Rustoleum Metallic rattle cans from Home Depot. I used NAPA 7220 primer on all parts, a few coats of color, then Rustoleum clear to cover.
Not as durable as a "real" aircraft paint, but much cheaper and easier to touch up. I'm overall happy with the way mine turned out, given the small amount of money I spent.
If you're going to mostly polish but just paint a few pieces, it's a good option!
Re: Rattle can
Postby Bryan Cotton » Thu Nov 14, 2013 8:48 pm
I think I am sold on the rattle can route. I took a liking to them on my former 1946 C140 project for priming old parts. Much more convenient than mixing small batches and cleaning up.
If anybody thinks I (we) are nuts to rattle can vs real spraying, I would welcome your thoughts too.
Re: Rattle can
Postby mike.smith » Thu Nov 14, 2013 8:51 pm
radfordc wrote: I did have some issues with the enamel. When I shot the black over the white I got a lot of "curdling". I may not have let the white cure long enough.
I had the same issues when I started painting with Rustoleum. Per the instructions on the can, you either have to paint additional coats withing a specified period of time (a few hours) or you should wait at least 48 hours [I think that's what the can says] before recoating OR before adding a clear coat. I was painting the color, then putting on the top coat a day later. Results: extreme orange peeling! Had to use paint stripper and start over. I got ahold of Rustoleum and they said the clear coat (especially) has chemicals that will react with the paint and orange peel any paint that is not COMPLETELY cured. So on my next paint jobs I primed, waited a couple of days, color coated multiple coats all in one night, and then I waited a WEEK before I clear coated. If I needed to do any sanding after the color coats, I waited a WEEK before recoating, and then waited another WEEK before clear coating. It's worked so far.
I know of at least one builder (I know there are more) that didn't clear coat at all. They just used car polish after painting, and that shines it up and adds some protection. They were happy with the results.
Re: Rattle can
Postby Bryan Cotton » Fri Jun 13, 2014 9:45 pm
All,
I painted a few cars as a kid, both lacquer and enamel. Lacquer got a lot of wet sanding between coats and then it was buffed out. Enamel I usually left it as sprayed, especially if I did a good job. Has anybody buffed out rustoleum before? I only used it to paint engines and stuff.
Re: Rattle can
Postby ScottM-Sonex1629 » Fri Jun 13, 2014 9:57 pm
Lol, Mike Farley has been talking with me about Rustoleum paint as well the last few days - the wet sanding and buffing to be specific. Hopefully Mike will chime in. He was not having good results with the clear and trying to buff it out.
Bryan I too have painted several cars (more recently using base coat / clear coat urethane on two and single stage urethane on another). Those paints are two part and harden really well and lend themselves to wet sanding and polishing/buffing. I find the 1x paints like Rustoleum are soft paints when you try to buff them out. When you think about it, the paint will lift if you wipe it with lacquer thinner...but your mileage may vary. The nice thing about 1x (1part) rattle can paints are that the paint is cheap, easy to apply, and if you don't like the results easy to apply another coat.
Scott Meyer
Sonex 1629 - Sold...9/2019
ScottM-Sonex1629
Return to Finish methods
