by n502pd » Wed Apr 09, 2014 7:55 pm
Mike, thanks much for the nice reply. mount is bonifide sonex from another member here who wanted to go with a corvair. mount is/was virgin, and no dents or bends, and installed without a problem. fuselauge is straignt and leveled on support structure. gear legs are at 34.0 inches per plans, of correct diameter and metalurgy. axels are scratch built, one appears to be 44+ deg and the other is about 44.5 deg...not a real deal breaker for this, IMHO. I dont have any real problem with the top of the legs sticking out above the mount, per se, but that isnt what the plans shows. Do other scratch builders have the same problem? Plans call for a 1/4 in hole, 1/2 in from the top end.I can get both axels and gear legs to meet the allignment specs otherwise.
However, I have not been able to expelicity determine the insertion depth of the leg into the axel. Mine go in 2.75 plus or minus a very small bit, but there isnt any call out for that on the plans, or at least my plans. have you got a spec that was sucessfully used? One other thing you said was if I got the legs from sonex (I didnt) but the plans show them to be exactly 34 in long. I would sure like to have someone measure a leg ( tail dragger config) that was purchashed from sonex to compare. my plans are up to date and nothing mentions cutting them
Sorry for being long winded! Thanks again for the assistance Mike! :)
Joe Nelsen
scratch built :D
Flying @78.2
KGYI/N. Tx Reg/Perrin Field
