SNX-F02 matched hole parts question
Posted: Sat Apr 05, 2014 10:48 am
Hi all
I am looking at plans page SNX-F02, specifically section C-C where SNX-F03-06R/L (right and left hand attach fittings) get mounted.
Using the matched hole kit with pre made angles, these fittings have no pilot holes for the rear spar attachment. The rest of the rear spar carry through assembly does....
So I am pondering how to drill the attach fittings when the other parts all have 3/16" holes in them....especially if it is installed in the fuselage....
At this point I am thinking to install the rear spar carry through assembly. Clamp these attachment fittings in place, then remove the assembly and use the drill press.
The attachment fittings have pre drilled holes for the fuselage mounting but the fuselage does not have pre drilled holes so this should work.
I am curious if anyone else has encountered this.....
Chicagoland
N1517S reserved
Chicagoland
N1517S reserved
