Wing Mounting
Posted: Thu Nov 02, 2023 12:28 am
As part of the recommended method of attaching the wings to the fuselage, Sonex recommend the application of WD 40 to the wing spar.
WD 40 is not particularly good lubricant - some would argue not a lubricant at all, rather being a water (W) dispersant (D) fluid.
- So what is the actual purpose of the WD 40 application ?
Depending on your opining/advice above - what alternatives/better products would you recommend?
