Rick
I think Frank is correct, need to adjust by 5 deg if working from the top surfaces only. For elevator neutral the top surface is down 5 deg in relation to the stabiliser top surface. With top skin of elevator aligned with the top skin of the stabiliser go up 20 deg to achieve 25 deg up. For down with top surfaces aligned go down 25 deg to achieve 20 deg.
Because a picture means a thousand words
- elevator travel.jpg (39.39 KiB) Viewed 4148 times
SNX-T01. is the drawing. For the 25 deg up it is shown as a 160 deg arc from top surface to top surface, stabiliser to elevator.
Sonex 892
VH-ZSX TD 3300
