Stall Tests
Stall Tests
Postby GraemeSmith » Sat Jun 27, 2020 6:33 pm
So while the wings were tufted for testing VG's - Flew some stalls on Friday. Managed to get a left and right camera ALMOST in synch for most stalls.
Re: Stall Tests
Postby GordonTurner » Sat Jun 27, 2020 6:53 pm
Hi Graeme (almost couldn’t resist adding “cracker”, fortunately I’ve matured beyond that stage in life).
1. What are you tufting with, tuft material and tape type.
2. Have you confirmed that you have full up elevator authority as per the plans?
3. Are you highly confident in your current t weight and balance information?0
Love the testing and the documentation. Look forward to further pushing out on the envelope.
Cheers, Gordon
Re: Stall Tests
Postby GraemeSmith » Sat Jun 27, 2020 10:29 pm
GordonTurner wrote:1. What are you tufting with, tuft material and tape type.
A fine acrylic yarn and thin duct tape (I'm going to regret this later when removing). The end of the wool is set in a rivet head and the tape firmly blended on top of it
GordonTurner wrote:2. Have you confirmed that you have full up elevator authority as per the plans?
Yes
GordonTurner wrote:3. Are you highly confident in your current t weight and balance information?0
Reweighed and balanced last Feb at Condition Inspection. So yes.
The idea came from some videos my upset and recovery CFI had made. They filmed the heck out of their tufted aircraft to make teaching points about what was going on with airflow that got you into upsets and what control inputs worked (and didn't) to get you back out again. As a visualization tool its useful. For fine measurement - a lot less so.
One thing that is apparent from reading about the VG's (Previous video) in some work by NASA is that VG's cause pressure differences on the wing. For full visualization you need:
- Smoke streams from the wind tunnel
- Flush Pressure sensors set in the wing skin
- Tufts are a poor man's sensor in comparison to the first two.
NASA has some interesting video of fully attached boundary layer smoke streams with quite different lift developed depending on speed of the air (expected)
But they also have fully attached smoke streams with quite different amounts of lift generated with the SAME airspeed but with the addition of VG's.
So tufts are useful but not really telling the whole story. I didn't consider them much more than "coarse" visualization tools as a result. What I have also found them useful for was confirming some of the "feel" I am getting doing acro - confirming some stuff that is just vibrating flaps and other stuff is me pulling too hard and getting accelerated stalls!
Re: Stall Tests
Postby Bryan Cotton » Sat Jun 27, 2020 11:04 pm
Great videos!
Re: Stall Tests
Postby n502pd » Sun Jul 05, 2020 12:50 pm
VERY VERY good demo, and data collection methods! great job! I am sure we all can gleen info from these videos! thanks much for your efforts here!!
Joe Nelsen
scratch built :D
Flying @81.7
KGYI/N. Tx Reg/Perrin Field
n502pd
Re: Stall Tests
Postby mike.smith » Sun Jul 05, 2020 8:13 pm
If you want to keep the spin going indefinitely, you don't need any aileron. Just keep the ailerons neutral, hold the stick full back and hold the rudder pedal. With an AeroVee (VW) you want to hold down the left rudder pedal. The AeroVee doesn't spin very well to the right; it mushes to the right.
I could have kept this left spin going forever, but stopped after 5 turns. I probably had 8 gallons in the tank, and me. Nothing else. So no rear CG.
https://www.youtube.com/watch?v=gPzQ3Ruq8LY
Same here, at 3:55. I had 10 gallons in the tank this day.
https://www.youtube.com/watch?v=1nD_tDJMEsE
Users browsing this forum: No registered users and 33 guests
