falvarez wrote:Hi Kip....I have a quick follow up to what you mentioned about the legs "floating" in the engine mount tube that I'm hoping you can confirm...
The top of my gear where the bolt is, is quite snug and because we used drilled bolts w/ castellated nuts, I don't have much torque on the bolt...my assumption is Sonex wants it that way or they wouldn't have mandated drilled bolts. Where the gear exits the lower fuse, there is some play. I thought Sonex has made comments in the past that the leg is supposed to be free to rotate there in order to help absorb the landing stresses. I have heard of some folks putting metal shims in there to tighten up the fit, but that seems to contradict the purpose of it...can you confirm that you did NOT put any shims in the lower mount to tighten the fit of the gear leg?
Also, Joe...when I put my axle on the gear leg, even though I feel I did a good job with the drilling, I found that there was some play (not the bolt hole...the axle tube was a bigger than the gear leg)...I could easily see this becoming an source of elongating the hold in the steel tube. If you have this similar issue in the axle, I would recommend using shims stock or something else to remove all play in the axle completely....but as you can see above, I'm still unclear if we should be removing any play in the engine mount.
