by rwthomas1 » Tue Aug 27, 2019 11:44 pm
Hello All,
I'm struggling with the Oops fitting installation. The three in the sump have been drilled out and cleaned. The custom installation/sanding tools work great for two, but I'm having trouble with the third. The small one that faces the right side, I believe? The hole is so close to the sidewall of the sump that the sanding tool fits at a slight angle. I can't get it to cut a smooth flat seat. There is a nice thick section of plastic on the sump wall from the original fitting. I have tried every Dremel bit I have, nothing can quite get at it. Same with chisels, and a bunch of other tools I tried. Any suggestions are appreciated. Beginning to think a new tank is a better idea....
Thanks, RT
