Video Tour of my Sonex
Postby mike.smith » Thu Jul 04, 2019 8:06 am
Hi, everyone!
I've been working on a video tour of my Sonex (built from plans) for several months and finally got it posted on YouTube. I focused on custom modifications and some lessons learned, to maybe help other builders who want some additional food for thought. It's a bit long at 1 hr and 25 minutes.
https://youtu.be/Lbgek8-X14o
As I note in the YouTube text, while I express some definite opinions that doesn't mean I'm right, so make your own judgements. I may do one in the future focusing on the AeroVee and firewall forward.
Re: Video Tour of my Sonex
Postby Rofomoto » Thu Jul 04, 2019 11:14 am
Lots of good tips... thanx. Billy
1735
Longassproject
Rofomoto
Postby WesRagle » Thu Jul 04, 2019 1:35 pm
Excellent!
Thanks Mike.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Postby Darick » Sat Jul 06, 2019 9:31 am
Mike, nice video!
One question...elevator trim tab B nut...what keeps the nut assembly from wobbling in the hole? I viewed the part in ACS and there are no threads on the B nut shaft which runs through the trim tab hole. It appears you would have to use washers and only a cotter pin to keep it snug, but still allow it to swivel as the trim tab moves.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Postby MichaelFarley56 » Sat Jul 06, 2019 11:12 pm
Well done on the video Mike! I love it!
I think this is a great idea for those with flying airplanes; virtual videos show details of airplanes which can be a huge benefit for builders. If I ever have the time to do it, I may try to follow your example and create a virtual video of my Waiex as well.
Thanks for sharing Mike!
Postby builderflyer » Mon Jul 08, 2019 3:39 pm
Mike, thank you for taking the time to prepare and share your video. It's always enjoyable to see the airplanes we love from another's perspective and maybe even pick up some new ideas at the same time. Good job.
Art,,,,,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,,,,Jabiru 3300 #261
builderflyer
Postby mike.smith » Mon Jul 08, 2019 10:58 pm
Darick wrote:Mike, nice video!
Hi,
You're right. It's been there so long I forgot some of the details myself. The two primary advantages for me are how much easier it is to adjust the trim, and the fact that there is no chance of that little Z popping out. I never liked that Z. Made me nervous how poorly it's secured.
Postby Darick » Thu Jul 11, 2019 7:26 pm
Another question...what did you use for the wing root seal?
Darick Gundy
Sonex #1646
N417DG
Darick
Postby mike.smith » Fri Jul 12, 2019 12:04 am
Darick wrote:Another question...what did you use for the wing root seal?
I don't remember for sure. Here are my two Kitlog pages:
http://www.mykitlog.com/users/display_l ... 0499&row=3
http://www.mykitlog.com/users/display_l ... 0535&row=2
Postby GraemeSmith » Fri Jul 12, 2019 7:19 pm
Bottle Holder. I retrofitted a polycarbonate one for bicycles. With no access to the spar box without taking the wings off - I used "60lb" double sided heavy duty Scotch Tape. It has a foam core and conforms between the bottle holder and the flat sheet of the spar box.
Let it set for two days. Survived an afternoon of hamfisted acro this afternoon with a bottle of water in it.
