by mike.smith » Sun May 13, 2018 11:58 pm
The original inner tubes I bought for the standard Sonex main wheels had the valve stem centered in tube, along the center inside seam. I'm now only finding tubes with the valve stem off center in the tube. That means the valve stem is not aligned with the centered hole in the wheel halves. Does anyone have a source for inner tubes with the valve stem centered? I've looked on Amazon and done Google searches but haven't found anything.
