by SonexN76ET » Mon Apr 30, 2018 10:25 am
Chris,
Your new video’s sound makes it much easier to hear the noise you are experiencing. Can you hear this on the ground? The video’s sound is reminiscent of the mechanical whine of a helicopter in flight. Can you hear any of this noise when you do a high powered run up on the ground? Could the prop hub be coming into contact with the cowling? Does the noise change with RPM or with airspeed? Any changes in oil pressure lately? If it is mechanical, I can only think of a few things it could be. Have you checked to make sure your secondary ignition and alternator components are secure? The reason I mention this is pumps can start to whine as they age indicating it is time for service and the alternator because some have reported the stator screws have loosened causing damage and or a loose trigger magnet shaft. Only other thing I can think of is the gears on the crank and camshaft somehow causing a whine. This is all pure speculation but might help you troubleshoot this noise.
Jake
Sarasota, Florida
