Aileron range of movement
Postby btaylor » Sun Dec 03, 2017 3:58 am
The plans show degrees of movement for the rudder and elevator. As I was checking the ailerons for initial control rod fitting, I couldn't find reference to how many degrees of up and down aileron there should be so that I'm sure I'm within limits. Have a missed this reference in the plans?
btaylor
Re: Aileron range of movement
Postby SNX1508 » Sun Dec 03, 2017 7:00 am
btaylor wrote:The plans show degrees of movement for the rudder and elevator. As I was checking the ailerons for initial control rod fitting, I couldn't find reference to how many degrees of up and down aileron there should be so that I'm sure I'm within limits. Have a missed this reference in the plans?
If you are building a legacy Sonex, see page SNX-C01 for a chart of all control surface deflections.
Ailerons:
UP = 20.5
Down = 11.5
Terry
Terry
Sonex #1508
N296SX
AeroVee #0736
Tail Dragger
SNX1508
Postby btaylor » Sun Dec 03, 2017 3:26 pm
Thanks for the info. Yes, I'm building a Sonex purchased in 2009.
Bud
btaylor
Users browsing this forum: No registered users and 64 guests
