fatigue crack and break of tail wheel spring
Posted: Fri Oct 06, 2017 11:42 am
Update: I didnt want to continue the other string with the update on my problems with the Ti rod tailwheel spring.
I did replace the Ti rod with one from Sonex, and have done one flight on it since install. All appears well. However there is still just a bit of slop at the aft end of the mount, as there was with the first rod. I did however, identify a small, 1/2 pin head sized dot of metal in the approximate location of the fatigue crack that initiated the failure. I took great care to remove the greatest amount without enlarging the opening more that it was already. I did add a piece of spring steel shim into the opening for about 3/4 inch ( that was as far as I could get it without destroying it) in an attempt to reduce the play. I could not elliminate it fully. I am back flying and attempting to also master my flare at landing!! Thanks to all for all the assistance with this. I did learn stuff!!!:)
