There is a very high likelihood neither of those contact points will be an
issue once your aircraft is rigged. The aileron bellcranks have their own
stops built in and these often come in to play before the ones on the
sticks.
We recommend you continue with your build and if those contact prevents you
from properly rigging your ailerons we can solve that problem then.
N111YX wrote:Interesting. I never thought of the phenolic bits as stops but rather mere spacers. Just going from memory, I would think that the travel of the bellcrank would be extreme to make contact...
sonex892 wrote:N111YX wrote:Interesting. I never thought of the phenolic bits as stops but rather mere spacers. Just going from memory, I would think that the travel of the bellcrank would be extreme to make contact...
The reason we would presume they are only spacers is because they are only referred to in the plans as spacers. Just re-adjusted my ailerons yesterday and couldnt get the bellcrank to bottom out on the spacers, or stops any way :cry:
Kip you mentioned earlier of using a taper pin instead of the bolt in the joystick mount. My joystick has just gotten sloppy again so I plan on doing the same. Did you use #2 or # 3 taper pin? I'm thinking of going #3.
Steve 892
