by dirkverdonck » Mon Jun 26, 2017 3:12 am
Hi,
First I added nutplates to install the glareshield and made the panel removable so I will be able to access wiring and instruments without removing rivets!
I temporarily installed the fuel tank to do the plumbing work, removed it to do the wiring and installed it all again afterwards. Also, a plexiglass firewall was installed at that time to allow to gestimate the best location for the firewall penetrations and the installation of all the stuff on the 'hot side' of the firewall.
All that took a little time but the end result is a firewall which does not look like Swiss cheese and everything is in the right place. Do it once correctly and you'll be happy for the time spent afterwareds.
- Attachments
- removable instrument panel
- plexi firewall
Dirk Verdonck
Leffinge, Belgium
Onex #117
