Windscreen installation- how to dimple the fuselage skin
Postby jowens » Thu Apr 13, 2017 10:40 am
Hi
What should I use to dimple the fuselage skin for the windscreen side bolts? The plans call for the 3/16" holes in the fuselage to be dimpled. The windscreen lexan to be countersunk.
Jim Owens
jowens
Re: Windscreen installation- how to dimple the fuselage skin
Postby rk2436 » Thu Apr 13, 2017 10:56 am
You don't have to use the countersunk screws,regular pan heads are fine. All the factory planes use the panheads. Dimpling that close to an edge it is hard to avoid a slight pucker. Looks better too.
Bob K
Orig builder kit 1143
Now flying RV-12
Evergreen Park,Il
rk2436
Postby ScottM-Sonex1629 » Thu Apr 13, 2017 6:24 pm
If you choose to dimple as the plans call for, I simply used one of the machine screws and a countersunk backing block (wood) and a hard plastic/rubber mallet to deform the aluminum to the shape of the screw. The 100 deg countersink bit works fine on the lexan.
Scott Meyer
Sonex 1629 - Sold...9/2019
ScottM-Sonex1629
