by sonex1678 » Thu Jun 30, 2016 2:13 am
Direct C51: Sorry, I was so entranced with the photos on your website, I missed your static port response...thanks. Are you just leaving an open line or are you going to install a "port" in the cockpit?
Michael: I found a photo of your aircraft in the Sonex completions area, and I believe I see where you located the static port (left side, a couple inches below the windscreen at about the mid point)--looks very do'able and very nice. I was wondering where you located the probe(s) on the wing(s)--the one I can see looks further outboard than the standard probe set-up. Did you move it further out the wing, and if so, for any particular reason? I too could install dual probes as I already have both the recommended probe and now the Dynon probe (later decision), but think I'll only install the Dynon since the right wing is already buckled up. I do plan on autopilot install if funds permit....
Douglas B Scripture
Sonex 1678
