by Jim B » Wed Oct 28, 2015 6:22 am
I have had the aero conversion hydraulic brake kit since it was first offered by the factory but have not installed yet. I am now getting ready to install them in my tri gear sonex. I am looking for advice on routing of the hydraulic line in the trigear configuration from the master cylinder to the gear leg. I have the brake lever set up on the left side of the cockpit per plans. Is it routed through the wing spar tunnel under the wing spar or some other way?
Thanks in advance
Jim Ballenger
snx760/jab2200
first flight SEPT 2009
Jim Ballenger
snx760/jabiru2200
first flight Sept 2009
Ocala,Fl
