achesos wrote:I would agree with David's comment on the flexible fuel line potentially causing more load / strain on the tank fittings in either case - shock loads (from a hard landing or maneuver) or resonant vibration. In a simple mass/spring/damper scenario, the less stiff hose will deflect more than the comparatively rigid tubing. This will likely cause more strain damage to the tank fitting than a tube that will only resonate at a much higher frequency or harmonic of that frequency. Combustion engines make lots of resonances due to engine orders, so worst case is the rigid fuel tubing going into resonance at cruise RPM. This means that the tubing is vibrating at its largest amplitude and causing the most stress on the tank fitting it can create. The odds of this 'perfect storm' are not likely, but certainly possible. More likely is that it does go through at least one resonance as the engine changes from idle to full power and back to cruise. The trick is to not let it live there. If you really want to know if / when it resonates, you have to watch it with a strobe light while matching engine RPM or use an accelerometer and related hardware to record it. The solution I'm choosing is the rigid tubing with some soft damper pads on the firewall to minimize total tube deflection to reduce strain on the ends (constraints).
Sean
Users browsing this forum: Google Adsense [Bot] and 37 guests
