WaiexN143NM wrote:Hi Gary , are u going to use the tob axels too? What brakes u plan on using? The tob axels will mate up to the hyd brakes from sonex, u will have to remove a short stub outside of the backing plate for the hyd bakes, but would be used if u going the mechanical brakes route. The axles are nice for jacking. Inside has a short stub to do so. For anyone w the standard sonex axels , tob sells backing plates that u can weld onto them to a least pick up 3 bolt holes for the hyd brakes. Tob sells the c90 brakes but numerous reports seems to be a little inadequate for the sonex weight. For a new build I'd go w the sonex gear legs, tob axels(for the ease of jacking up the plane and mounting the sonex hyd brakes) . U will have to also plug and tap the outer hole of the tob axel to have a center screw for the wheel pant. Cheer's and good luck. Heading to the rio Linda fly -in tomorrow.
Michael RADTKE
tonyr wrote:I'm using titanium legs, TOB axles, and the standard mechanical brakes.
I had to turn up a 3/8" spacer between the axle plate and the brake backing plate. Pretty solid with 4 bolts holding it on.
The wheel pants are attached with 2 10/32 threads tapped into the brake plate. I machined an alloy stub to insert into the axle end, drilled and tapped for a single 10/32 screw. The insert is held in place with the cotter pin.
A stub on the brake handle locks behind the flap handle for a park brake.
Works adequately for what I want.
Nice to know the Sonex hydraulic units fit the axle too.
garyb wrote:I am thinking of using the Tracy O'Brien gear legs and 6 inch wheels for my std gear Sonex. I Any one else using ether of these options.
