Why not Rotax
Why not Rotax
Postby jjbardell » Fri May 01, 2015 4:53 pm
As I continue my search for my perfect Sonex, I have come across a few in other countries that use a Rotax 912is Sport or 914 Turbo.
Why isn't that a popular engine in the Sonex? Just curious as there isn't a lot on Sir Google about this blend of motor/airframe but seems to be a logical fit imop.
N83LJ - Sonex #0864 (SOLD)
jjbardell
Re: Why not Rotax
Postby SNX1508 » Fri May 01, 2015 5:45 pm
I can only speak for myself of course, but I did not choose the 912 or 914 due to cost (could buy another airplane kit for the cost of an engine?) and neither are supported by Sonex.
Terry
Terry
Sonex #1508
N296SX
AeroVee #0736
Tail Dragger
SNX1508
Re: Why not Rotax
Postby garyb » Fri May 01, 2015 9:45 pm
I am putting a half life 912s in my Sonex,my first choice was an Aerovee but I picked up the Rotax for a good price, just started making the engine mount.
Sonex #1531 Rotax 912ULS. 250 hours and counting.
garyb
Re: Why not Rotax
Postby rizzz » Sat May 02, 2015 6:16 am
SNX1508 wrote:I can only speak for myself of course, but I did not choose the 912 or 914 due to cost (could buy another airplane kit for the cost of an engine?) and neither are supported by Sonex.
Terry
Same here, cost.
Re: Why not Rotax
Postby sonex892 » Sat May 02, 2015 7:23 pm
Terry
Same here, cost.
Had the current Jabiru problems surfaced before I bought my 3300 early 2010 I would have more than likely bought and used a 912s Rotax. At the time the decision was made on cost. The Jabiru was 2/3 the price of the Rotax.
I would not be too concerned with not having the factory support.
Sonex 892
sonex892
Re: Why not Rotax
Postby MichaelFarley56 » Sat May 02, 2015 10:56 pm
I believe the Rotax engine, while successfully grafted onto the Sonex airframe by a few builders, was never a recommended engine based on both cost and complexity. Most Rotax engines are both air and liquid cooled which means you'll need radiators, water pumps, coolant, etc. This adds weight, cost, complexity, etc.
As others have said, it's also an expensive option.
Re: Why not Rotax
Postby Concorde » Sun May 03, 2015 7:23 am
How much does a Rotax weigh including the radiator and pump and coolant ?
Ben
Sonex # 1684
Tri-Gear, Dual Control
Rotax 912uls
N379BS reserved.
Concorde
Re: Why not Rotax
Postby rizzz » Sun May 03, 2015 8:13 am
Concorde wrote:How much does a Rotax weigh including the radiator and pump and coolant ?
Installed weight is 140 lbs for the 912ULS, 166lbs for the 914UL.
Weight is not an issue with Rotax, even with radiators, cooling liquid etc.
I don't personally buy the complexity argument as being a risk either. These engines have proven their reliability, probably beyond the sonex approved engine options.
Cost however....
Well, you can build a Sonex including AeroVee engine for that price.
Re: Why not Rotax
Postby Concorde » Sun May 03, 2015 4:58 pm
Thanks for the info Michael .
Ben
Sonex # 1684
Rotax 912uls
N379BS reserved.
Concorde
Re: Why not Rotax
Postby jjbardell » Tue May 05, 2015 8:49 am
Great info!
jjbardell
