Sonex POH
Sun Oct 02, 2011 2:26 pm
by chubbybrown
hi does anyone have an electronic copy of the sonex tricycle POH, either pdf, word etc that they could send me?
i have seen the N604X POH on the net but thats for a tail dragger or is there much if any difference on the tricycle version.
thanks in advance
Re: Sonex POH
Sun Oct 02, 2011 6:18 pm
by MichaelFarley56
There really shouldn't be too many changes is you use the N604X one, assuming you're using the Aerovee. I've started mine, basically using that one as my template and then making individual changes as needed for my own airplane. Are you building your own plane? Is it an Aerovee? I would say, just use that one, and adjust it slightly as needed for your plane.
Re: Sonex POH
Sun Oct 02, 2011 11:48 pm
by N111YX
Does Sonex not sell them?
Re: Sonex POH
Mon Oct 03, 2011 6:54 am
by chubbybrown
MichaelFarley56 wrote:There really shouldn't be too many changes is you use the N604X one, assuming you're using the Aerovee. I've started mine, basically using that one as my template and then making individual changes as needed for my own airplane. Are you building your own plane? Is it an Aerovee? I would say, just use that one, and adjust it slightly as needed for your plane.
hi michael,
thanks for the reply, yes its an aerovee engine.
