Flying Sonex For Sale
Postby Sonex 772 » Wed Oct 15, 2014 1:25 pm
SONEX FOR SALE
This Sonex was built from a kit with by a two time Sonex Builder with excellent workmanship.
This is a Standard Gear (Taildragger) Sonex with Dual Sticks, and lots of nice options. First flight 4-26-2014
40.0 Total Time on Air Frame, Total Time on Engine 40.0 hrs.
Hours will change as the plane is flown often.
The Sonex also has:
Acro Ailerons
Todd’s Windshield/Canopy
Aveo Powerburst Wing Tip Lights
Wheel Pants
Gear Leg Fairings
Fiberglass Wing Tips
Fiberglass Tail Tips
Pilot and Passenger NACA Ducts Fresh Air Vents. Rear NACA Duct for rear air exit.
Instruments Include:
MGL Enigma with 6 CHT, 2 EGT Probes, Oil Pressure Sender, Oil Temp Sender and SP2 Compass.
MGL V10 Transceiver with Comat Belly Antenna
Flight Data Systems G-Meter
Garmin 320A Transponder with Antenna
Falcon ASI 0 – 200 MPH
Vernier Throttle and Mixture Cables
K4 Lighted Rocker Switches
W58 Series Circuit Breakers
Vans Vents
Engine Information:
AeroMax IFB100 Corvair Engine with 5th bearing, rated at 100HP
Engine Mount
Sonex Cowling
Fence Baffle System
Full Flow Oil System
Oil Cooler
Oil Filter
Ceramic Coated Exhaust Pipes
AeroCarb with Filter and 3 needles, 2.0, 2.5 and 3.0 sizes
Dual Coil Ignition
35 Amp Alt.
Props Inc 54x44 Wood Prop with Resin Leading Edges
Sonex Spinner
Weight:
Empty weight 710 lbs
Gross weight 1150 lbs
Performance:
Rate of Climb: 1230 FPM @ 80 MPH @ Sea Level
Cruise Speeds: 145 MPH @ 2800 RPM @ Sea Level
165 MPH @ 3250 RPM @ Sea Level
Fuel Burn: 5 Gallons per hour @ 3250 RPM
4.5 Gallons per hour @ 2800 RPM
How to see the Sonex in action:
Here is a link to the first flight on Sonex #509 on youtube.
https://www.youtube.com/watch?v=q1dhfxJmAIs
Flight number 10 can also be seen on youtube.
https://www.youtube.com/watch?v=k_kEX_lAxGE
Sonex #509 First X-Country Trip can be see here:
https://www.youtube.com/watch?v=kKQ8aAQYti4
Pictures of Sonex #509 can be see at this link.
https://www.flickr.com/photos/sonexbuil ... 802372582/
Price of Sonex #509:
$39,500.00 OBO
Call Mike at 541-698-0428
Or e-mail: sonex772@yahoo.com
Sonex 772
cron
