by MichaelFarley56 » Sat Sep 10, 2011 8:56 pm
To begin answering your question, let me first say that I have yet to fly my Waiex so I can't comment on how much air my vents will provide, but like most I elected to purchase the NACA duct/air vent kit from Vans Aircraft. For (if I remember) less than $100 I got the kit that includes two vents, drawings to cut out the vents, ducting tubing, and the interior monted plastic adjustable vents.
To install these vents, I cut out the side skin using the provided template, and then secured the plastic vents using black RTV and several CCP-44 rivets. If you decide to go this route, make sure you put the vents in a location that doesn't interfere with the brake and flap handles.
Also, while you are ordering the vent kit, a lot of people also order two wing root seals to use as well.
Best of luck as you continue the build! :D
Waiex #0056 - N569KM
Jabiru 3300A #1706
