kmacht wrote:The flutes in the upper firewall and the bow strap holes is a know issue with the Sonex. Most of us just straightened out the flutes that interfered with a pair of seaming pliers and then re-fluted a little further over. If you are getting warping when fluting then either put a deeper or shallower flute in depending on which way it is warping. If you over flute, just squeeze it back flat a little bit with the seaming pliers. Adjusting the flutes in or out is how you get the part flat in the first place. It only takes a minor ammount of adjustment to make the whole panel move one way or the other.
Rick524 wrote:I'm just about finished building my upper firewall....in my experience, you need lots of the following: Bits, Boe lube and Band aids. ;)
Users browsing this forum: No registered users and 57 guests
