MichaelFarley56 wrote:I've had shimmy issues that were cured by making darn sure all bolts were snug (especially the upper gear leg bolt that goes through the engine mount) and making sure the alignment of the wheel halves kept the actual wheel turning straight. At first, when I assembled the wheels the wheel halves were at a slight angle which caused the wheel to spin untrue.
Have you balanced your wheels? That always helps a little. Also, where are you running your tire pressures?
fastj22 wrote:I used Dynabeads to balance my tires. I don't have a shimmy problem and can't prove these are the reason. But its cheap and makes sense.
I also used them on my sport bike.
http://www.innovativebalancing.com/index.php
Users browsing this forum: No registered users and 65 guests
