tips on installing vertical tail skin
PostPosted: Sat May 31, 2014 12:11 pm
by sonex1649
Any good tips before installing vertical tail skin.
Thanks Joe
Re: tips on installing vertical tail skin
PostPosted: Sat May 31, 2014 12:38 pm
Joe,
No vertical on a Waiex but it should be the same. Need a flat table to keep it true. I hung one side of the skin off the table for the first set of holes. Flip it over, get a couple of clecoes in the aft spar to hold it in place, then go to town. I did the ribs forward of the front spar last. Did them from root to tip on both sides. That way if there is any looseness it goes to the leading edge and it looks good. Take apart, deburr, and if you are polishing do it before you rivet.
It's almost too easy.
PostPosted: Sat May 31, 2014 5:11 pm
by sonex1649
thanks Bryan, by the way I see yours every post love the polish work
PostPosted: Sat May 31, 2014 5:42 pm
by sonex892
I don't know if the Sonex tail tips are still installed sandwiched between the skin and rib? If so, leave about the last 4 rivets out of the skin until the tip is in and aligned.
Line it up with the rudder.
Aluminium rivets? Worth considering
PostPosted: Sat May 31, 2014 6:52 pm
by SNX1508
sonex1649 wrote:Any good tips before installing vertical tail skin.
Thanks Joe
Joe,
I initially clecoed skin with v-stab laying on the bench, but ended up clamping the assembly to the workbench in a vertical position, which kept it stable while riveting skin and the tip. While clecoing, I put spacers between the rib and skin where the tip would be installed later.
As already posted I also worked from the root to the leading edge. I used S.S. rivets on the tip, but wish I had used aluminum.
See PIC's here.....
http://www.mykitlog.com/users/display_l ... 130&row=54
If you go back a little further in the log you'll read about my difficulties mounting the tip, which was not moulded symmetrically from Sonex.
Terry
PostPosted: Sat May 31, 2014 7:08 pm
by sonex1649
thanks guys
PostPosted: Sat May 31, 2014 8:53 pm
Thanks Joe for the compliment! Are you going to polish? Come to the shiny side, Luke...
PostPosted: Sat May 31, 2014 8:55 pm
by sonex1649
Yes I am I think it looks great and I'm thinking black tips and your welcome
PostPosted: Sun Jun 01, 2014 9:24 am
by Rynoth
FYI, received this via email from Kerry awhile back, regarding the use of aluminum rivets in the main wing tips and the tail wips.
"You can use aluminum rivets on the wingtips, as they are non-structural, but not on the tail tips."
I read that as Sonex recommending you stick with the SS rivets in the fiberglass tail tips, probably since they are subjected to airflow.
PostPosted: Sun Jun 01, 2014 10:58 am
by Fastcapy
