Sonex elevator trim tab
Postby mike.smith » Mon May 26, 2014 7:04 pm
I received my airworthiness certificate yesterday on Sonex #439 (plans-built) - yay!
The only comment/question my DAR had was about how the standard Sonex elevator trim tab cable was attached to the trim tab. The plans just call for a "z-bend" in the wire. What we found is the cable can actually go through the hole (further up the cable; not in the direction of detaching from the tab) if the trim tab gets enough force on it. That puts the trim tab in a full-down position, that will not clear itself. I have to agree it's a tenuous connection.
Has anyone done something different? I'm cognizant that we don't want to be adding a bunch of weight to the trim tab.
Re: Sonex elevator trim tab
Postby N1906R » Mon May 26, 2014 8:16 pm
Congratulations on your airworthiness cert.
On my trim tab the i went as per plans but I took a lot of pictures and this one was from Oshkosh. You can see the hole was enlarged and the same cable pivot used on the brakes was used on the tab. I was going to drill mine for this but found the hole was to close to the edge to be enlarged that much and I would have needed to make a new tab. Maybe someday but I've had no issues with mine the way it is so far. I hope this helps.
Keeps us informed on your first flight.
133 - Copy.JPG (39.68 KiB) Viewed 2623 times
Jim Reichard
Sonex814
N1906R
3300 Jab
Standard Gear
N1906R
Postby mike.smith » Mon May 26, 2014 9:04 pm
Thanks for the photo. I have one of those pivots lying around, and I thought of that. I may take a look and see if that would work on mine. That seems like the lightest solution.
Users browsing this forum: No registered users and 78 guests
