by Sonex1517 » Tue May 27, 2014 9:22 pm
I completed drilling the tailwheel assembly in place today.
I disassembled the tailwheel from the pivot assembly, and clamped it up in a small vise. I used a small pilot drill this past weekend to make a starter hole in the tube where the tailwheel spring slides in, and marked on the titanium spring with a red sharpie how deep it had to be so I knew it was set in place
Today I mounted the tailwheel bracket in place and set the angle for the tailwheel, then marked the spot on the titanium tailwheel spring with the pilot bit.
I then disassembled it again, put it back on the drill press and updrilled the whole thing in separate steps.
Worked out great and came out very nicely.
Chicagoland
N1517S reserved
- Attachments
- ImageUploadedByTapatalkHD1401239757.125246.jpg (86.19 KiB) Viewed 4500 times
