Tires/Gear Leg/Toe In
Re: Tires/Gear Leg/Toe In
Postby Bryan Cotton » Sat Nov 25, 2023 2:20 pm
Weight is the enemy! My latest Cheng Shin tire and tube weighed in at 3.16 lbs. My worn tire was 0.6+ lbs lighter.
Cheng Shin weight.png (475.44 KiB) Viewed 7324 times
Postby DCASonex » Sat Nov 25, 2023 4:38 pm
Have the 5.00 x 5 tires on mine and never needed more than 25 PSI. Have just over 500 hours on the tach. Most of that landing on pavement and on the first set of tires. I would be wary of using over 30 PSI with those bigger tires. The larger sidewall area means more force pushing outward on the rims than with the smaller stock tires for a given air pressure.
Postby Bryan Cotton » Sat Nov 25, 2023 5:01 pm
Can anyone tell me what the weight of the 5.00x5 tire and tube is?
Postby Skippydiesel » Sat Nov 25, 2023 5:27 pm
Bryan Cotton wrote:Can anyone tell me what the weight of the 5.00x5 tire and tube is?
The Goodyear specificaton document https://www.aps-aviation.com/wp-content ... e-data.pdf has all their weights (I presume without tubes). Naturally the weight varies across "model" & ply rating, for a given size (5.00-5)
Skippydiesel
Postby Bryan Cotton » Sat Nov 25, 2023 6:00 pm
I'll have to weigh one of my tubes. But the lightest 5.00x5 tyre I found in that chart was 4.9 lbs. I think by the time you add tubes that is a 5-6 lb weight increase. Hard pass for me!
Postby Skippydiesel » Sat Nov 25, 2023 7:23 pm
Seems my Goodyear Flight Custom III, 5.00-5 are 6 ply, so according to the chart 50 psi.
I assume 50 psi is Max pressure - seems a tad high for a light aircraft, like the Sonex but will give 40 psi a try out. My tyres weight 3 kg /6.7 lb each.
Skippydiesel
Postby 13brv3 » Sun Nov 26, 2023 10:00 am
AirTrac 5.00-5 4-ply tire is 4.5 lbs. I have a pair I haven't installed yet. I don't have a weight for the tube.
Rusty
Fixed wing, gyroplane, A&P
13brv3
Postby builderflyer » Mon Nov 27, 2023 11:25 am
Bryan Cotton wrote:I'll have to weigh one of my tubes. But the lightest 5.00x5 tyre I found in that chart was 4.9 lbs. I think by the time you add tubes that is a 5-6 lb weight increase. Hard pass for me!
Bryan, I believe going to the larger 5.00x5 tires is probably the largest and most common mistake most builders make.. The weight penalty is severe, the cost penalty is outrageous, the braking action may even be reduced, and they're simply not needed on the Sonex. The smaller tires are perfectly adequate on the Sonex and if one keeps them inflated at 45-50 psi, they don't go flat.
Even Tony Spicer, who began flying his Sonex with the larger tires, eventually switched back to the smaller tires with success, and he was based on a grass field. Guess which tires I have on my Sonex.
Art,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,,Jabiru 3300 #261
builderflyer
Postby tps8903 » Mon Nov 27, 2023 12:03 pm
Parts availability could be a concern. I blew my tire in North Tampa and needed to get home. Most A&Ps have 500x5 in stock, not so much 11x4x5. So I made the switch out of what was available and they work much better on my sand/turf field here in Florida, actually they roll sooooo much better. 90% of my operations are on turf.
Chris Morris
Sonex N998PC - SOLD!
Sonex #1732 - Aerovee Turbo
Central Florida
tps8903
Postby Bryan Cotton » Mon Nov 27, 2023 12:41 pm
In defense of the small tires, I will say I flew to a couple of 2100' grass strips this weekend. Of course to do it, had to pick the right conditions. Cold, windy down the runway, and solo. Took more power to taxi and takeoff roll longer than hardtop, but it was fine. I can't see going with big tires to optimize the airplane for a mission that it is not really suited for. It will never be a super cub.
