Tony4aro wrote:BRS wrote:
Would you mind sharing the model so I could print a set of stops?
Brock,BRS wrote:jklPDXPilot wrote:Brock, where do you fly out of? I see Woodland and Scappoose freqs on your radio in the picture.
I fly out of Scappoose and am considering building a Sonex.
Would you be open to showing me your plane?
James
Sure James, come on over. PM sent.
As a followup on the sight picture I've made a few rigging changes that I think will solve things. I first started by tickling down the flaps switch (while in flight). Just a slight change made all the difference in lowering the nose. Then back at the hangar I looked closely and noticed that the flaps were up from the ailerons about a 1/2". When I set them up I did my best to align with a straight edge on a curved wing like the plans say but straight and curved don't agree. So this time I zeroed my electronic 6" protractor on the trail of the wing in front of the flaps then compaired to the trail edge of the flaps. The difference was 2 deg. So after turning the heim joints out 1-1/2 turns I had the flaps angle matching the wing and they also aligned evenly with the ailerons. How about that! I've not flown since as I'm replacing the AeroInjector with a Rotec carb.
The second thing I did was to print four of Peter's flap stops (pireted them from pictures and descriptions, hope you don't mind too much Peter). So with these installed, the flap comes up to where they should be and no higher. Again, waiting for the Rotec installation to go test it all out.
Brock,
Never got your PM. I sent one to you, but never heard back and am seeing other posts of missing PMs. Maybd a forum issue?
In any case, would still like to connect.
James
Skippydiesel wrote:At 100 knots my Sonex will have a fairly pronounced nose high - how come you cruise at this air speed?
Users browsing this forum: Bing [Bot] and 28 guests
