The Tool Shed is almost ready for flight. The cowl is modded and primed (see below), aircraft weighed yesterday (654#s), fuel flow test accomplished. I have one nagging, but not really all that important, question.
Q. Should I install the elevator bungee or not?
The previous owner never installed it and he said it trimmed just fine. How ever the purest in me realizes that if there is a lot of trim deflection then there is increased drag (admittedly, not much). The bungee reduces the amount of required trim deflection.
Cowl: So the RevMaster cowl mod is nearly finished. It's done enough for flight, with just cosmetic clean up and paint left. I like the look of the extended snout but it sure makes lower cowl installation more difficult as it will no longer hinge up from the firewall and clear the prop. Here are some pics.
- click to see the full image
- 20210925_134303s.jpg (238.49 KiB) Viewed 5043 times
