by Wingman » Thu Dec 14, 2023 10:42 am
Keith,
Glad to see you are giving this a try. You are correct that one still needs to make a spacer/adapter plate for the mag trigger plate. If you look at my pictures, you can see I did that also. My suggestion to mill out the engine mounting plate was just to get it all closer to the engine rather than being completely aft of the plate. My thought is that it would reduce some of the added weight also, which you have confirmed by your indicated weights. When I reweighed mine after completion, I added almost 7 Lbs. Still better than an automotive alternator but too heavy for the Sonex.
Mine is still running flawlessly and the extra amps have been adequate for all of my equipment with some to spare. With all electrical equipment on at once you will hear the load on the engine. It creates a slight drop in RPM.
I will look forward to seeing your improved version. sounds like you are putting more engineering into than I did.
MN Wingman
