SonAl wrote:Quick question for those with the manual trim lever: where did you source your cable to the trim tab from? I can’t find the cable/wire that is called out on the plans on the Aircraft Spruce website.
Thanks.
Al Arbuckle
pfhoeycfi wrote:I'm putting the dial a trim in my Sonex B. The plans call for connecting the down spring to the channel just below the flap torque tube, the other end to the elev push rod. The problem is is that the torque tube is in the way...so if you connect the spring to the channel and the other side to elev push rod, the sprint has to bend around the torque tube (making contact to about 1/4 the circumference of the torque tube). All my parts are in the right place.
I'm curious if any B builders with Dial a trim see the same problem and if so, did you secure the end of the spring somewhere other than where the plans indicate?
peter
