Rotax engines
Re: Rotax engines
Postby SvingenB » Sat Mar 08, 2014 5:01 am
There is no mixture control on a Rotax with Bing carburetors.
Reserved LN-ENX for Onex #134
Onex build log
SvingenB
Re: Rotax engines
Postby patrebert » Sat Mar 08, 2014 10:20 pm
Was referring to the aftermarket solutions available, which to my understanding regulate float bowl pressure in order to lean the mixtures.
patrebert
Re: Rotax engines
Postby rizzz » Sun Mar 09, 2014 5:47 am
Not sure what aftermarket solutions you're referring to but why would you want to replace standard Bings anyway?
Re: Rotax engines
Postby radfordc » Sun Mar 09, 2014 11:08 am
You don't replace the Bing carbs. The HACman® High Altitude Compensation/Manual Mixture Control for Rotax 2 stroke is a valve connected to the carb bowl vent that meters air going into the bowl. By reducing air pressure in the bowl the mixture is leaned.
http://www.greenskyadventures.com/bing/ ... etails.htm
Re: Rotax engines
Postby 1planeguy » Sat Mar 29, 2014 1:25 pm
Have installed several 912's...good solid number firewall forward, radiators, hoses, coolant...everything but the battery to crank it and fuel to run it, 160-165 lbs. Was weighed when a complete install was lifted from a plane, mount included and hung from a scale.
1planeguy
Users browsing this forum: No registered users and 64 guests
