sonex293 wrote:The cause of engine out? I had wired something too close to a hot point in the engine that was critical. Once the wire melted and created a short, the engine quit. I encourage everyone to get a second set of eyes on your project to see things you might overlook.
Michael Crowder
ex Sonex N293SX
I don't know that the seat, as designed, would collapse to the floor. There are a lot of rivets to shear or edges to tear out. I also think you would see the bottom floor collapse up toward the pan if you had gotten far enough to flatten the gear.
tonyr wrote: There are the pieces of channel that run directly under your coccyx. The lowered seat mod can bottom out on that channel if its down too far, as I found out. That is a greater risk to the spine in a vertical deacceleration. So much so, I raised the seat sling up about 20mm and I have placed some styrofoam blocks under the seat area either side of the channel to create a crush zone, and combine this with some decent foam cushioning on the seat to provide some spinal protection.
vigilant104 wrote: Tony,
Have you taken a look at the force needed to break the seat pan free so that it can collapse onto/take advantage of the styrofoam blocks underneath? For example, if it turns out that it takes 50Gs to cause the rivets to rip through/shear off, then the spinal damage will already have occurred before the styrofoam could come into play.
