Where the back of the canopy meets the turtle deck
Re: Where the back of the canopy meets the turtle deck
Postby mike.smith » Fri May 08, 2015 8:13 pm
DCASonex wrote:If you have not fitted your canopy or windshield yet, consider bonding a double layer of black felt on top of forward bow strap so that it is held in place by the windshield, and provides a bit of cushion and seal for canopy. Not a perfect seal, but quick cheap and some improvement.
I haven't flown in the rain so I don't know if this would help that issue, but I had quite a bit of air that used to come in around the forward bow, until I did this:
http://www.mykitlog.com/users/display_l ... 2003&row=2
http://www.mykitlog.com/users/display_l ... 2004&row=1
Last time I went flying I checked and wasn't getting the slightest bit of air coming in.
Postby Sonex1517 » Fri May 08, 2015 11:30 pm
Thanks for posting that! Needed to see a solution to this...
Chicagoland
N1517S reserved
Postby mike.smith » Fri May 08, 2015 11:39 pm
Sonex1517 wrote:Mike
Chicagoland
N1517S reserved
I got this solution from Dudley Foster (Onex), so he deserves the Kudos for that one :-)
Postby vicdelgado9 » Sat May 09, 2015 12:11 am
Excellent solution, I hope to do that to my canopy as well when I get to that point. The photos really help to understand the concept. I would have been lost without them. I appreciate you posting them Mike.
Vic Delgado
Sonex "CorVex" #969 Plans
Houston, TX
Expercraft Builders Log
vicdelgado9
Postby Sonex570 » Sat Jun 11, 2016 3:37 pm
Use the rubber baffling trim that came with your aerovee, I was able to sandwich in in nicely between the turtle deck bulkhead and skin and acts as a tight weather strip when the canopy lowers on against it
N570SX
Center Stick TD
120HP Corvair STEEL-X
1956 PA22-150
1999 CGS Hawk Arrow
CX4 Trigear (Aerovee with GP Crank)
Sky Cycle trike
Gyrocopter
Pittsburgh PA
Sonex570
Users browsing this forum: No registered users and 64 guests
