by tonyr » Tue Jul 15, 2014 6:32 pm
We had an instance of gear leg shimmy at a flyin this weekend past.
The Sonex in question normally operates off grass strips with 5.00 x 5 tires but during takeoff from a bitumen runway, shimmy from the RH main was noted by the airport operator sitting in his flight hut office...a couple hundred yards away! The pilot of course felt it as well.
We jacked up the aircraft on its return and indeed the leg was able to be rotated slightly in the gear socket, and the axle was slightly loose on the leg.
The bolts were able to be turned with the nut held, indicating the bolts were not broken. The LH hand side also had some play in both areas.
After retorquing the nuts, the play in the legs was gone. We suspect the wear and tear of landing on grass had allowed some extra wear in the bolt holes. SB-006 says they should not be overtightened but if they're too loose you get this problem I think. The top bolts couldn't be removed for inspection a they were inserted from the rear during construction.
Because of that they are still the stainless bolts by the way, (the SB says replace if broken or as soon as possible).
Anyway it was enough to get the aircraft safely back to home base.
The aircraft is due an annual so we will be pulling legs, doing the SB and inspecting everything!
Highlights that these bolts need to be regularly checked, especially operating off grass with 5.00 x 5 tires..
Cheers
Tony
