I never set out to measure this number to the precision you want, but I did find a gross-weight flight where I performed two stalls and I flew in enough directions that I believe I can estimate the wind speed.
Aircraft weight: 1125lbs (took off at 1150lbs and burned ~25lbs of fuel; this flight was performed at greater than Sonex's recommanded gross weight for the Aerovee engine.)
Density altitude: 4000ft
Tailwind during the stall: 7mph (my greatest uncertainty, but I did record GS and TAS while flying around in several circles, so feel like this is a reasonable estimate)
Minimum GPS ground speed during the stalls: 43mph (35mph IAS)
Estimated clean stall TAS: 50mph (43mph+7mph)
Stall speed corrected to sea level density altitude: 50mph * sqrt(1.088/1.225) = 47mph
Sonex lists the clean stall speed as 46mph. I feel like my estimate of 47mph agrees remarkably well with theirs. Both are comfortably within the LSA rule of 51mph.
Here's a recent quote from John Monnett about the fuselage lift:
“They’re basically a box with a lifting body that’s created by a smooth canopy and cowling transition. That contributes tremendously to its performance at both low-speed and high-speed operations.”
I'd be interested in seeing a comparison against other more rounded fuselage designs.
